clear corner bulbs
Old Nov 5, 2004 | 09:51 PM
truplay8's Avatar
THE BATMOBILE
clear corner bulbs
i changed my bulbs (194's) to a blue bulb, but at night the corner appears to be green.........can anybody recommend a brand name of a bulb that looks reallllllly blue.
03 coupe
19 inch RH Evolution GT5's black, Toyo T1's
Pro-1 Exhaust
clear corners
Escort X50 Blue
Momo shift ****
Old Nov 6, 2004 | 10:38 AM
annual's Avatar
Re: clear corner bulbs
piaa blue led wedge bulbs.
www.optauto.com
annual's Avatar
www.optauto.com
I have a set for sale, if your intrested. 2 for the clear corners and 2 for the side markers.
Old Nov 6, 2004 | 05:40 PM
truplay8's Avatar
THE BATMOBILE
can i have a specific link to purchase them...........i cants find them on the website
03 coupe
Pro-1 Exhaust
clear corners
Escort X50 Blue
Momo shift ****
Old Nov 6, 2004 | 07:23 PM
Kyosho's Avatar
just so you know, the piaa blue bulbs are VERY visible and chances are you will get pulled over. i ran some chrome bulbs from pepboys for quite some time with no problem. the headlight drowns out the blue when you want to hide them.
Old Nov 6, 2004 | 08:37 PM
annual's Avatar
Ya my friend alrady got pulled over, with them that I installed for her. It was 125 fine.
Old Nov 7, 2004 | 08:34 AM
GR8TG35's Avatar
Depending on your local, running real blue lights in the corners or clearance lights may get you a fix it ticket or fine.....
I like the blue look myself, but went for a more subtle look with the Extreme whites ....
Go with Piaa Extreme white/blue LED if you want a blue color
try importperformancewarehouse.com I had mine in two days....and the prices were very reasonable
04 cpe JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Nov 7, 2004 | 03:34 PM
truplay8's Avatar
THE BATMOBILE
are these the ones you suggest??
http://importperformancewarehouse.co...l?v=1&pid=1765
03 coupe
Pro-1 Exhaust
clear corners
Escort X50 Blue
Momo shift ****
Old Nov 7, 2004 | 05:12 PM
GR8TG35's Avatar
Those are the bulbs I used, however, the digital picture makes them appear more blue than with the naked eye......
If you are looking for a blue color, I suggest you check out this thread It should give you a pretty good idea of all the different Piaa bulb/Led combinations everyone else has tried......
Good luck with you choice.....
Old Nov 7, 2004 | 05:14 PM
GR8TG35's Avatar
Another shot with my Piaa Extreme Whites and MTEC super white H4 fog/high bulbs that I installed last Feb......
These are the LED's I had mentioned earlier in the thread. The Blue/White LED is the one that has some blue appearance...the BLUE/BLUE is true blue like the Pic of Afr0puff's car in the "lights the final answer" thread....
Old Nov 7, 2004 | 05:34 PM
Sukairain's Avatar
IMO none of the clearance bulb I've seen so far are bright enough. I went from 4LED to 6LED, tried the PIAA LED, and now considering moving up to either 9LED 230ma or the new PIAA Tera (1W) setup. It takes a lot of light to sufficiently illuminate the whole clearance strip, and thus far most of them are too dim.
CPV35 G35C Maliblue
Old Nov 8, 2004 | 12:35 PM
Diesel1's Avatar
Moderator
I notice on the clearence strip, if you look closely where the bulb goes (from the outside) you can see that light fixture actually has a little wall like tab that appears to block some of the light from traveling down the clearence strip. Probably gonna be tough to find sumtin that will fill that section completely w/o having ahot spot at the top!
I dunno why Infinity didn't design that a lil better to allow more even lightflow!
www.gsquad.org
Old Nov 8, 2004 | 02:23 PM
GR8TG35's Avatar
it maybe to prevent a loose bulb from falling all the way in the strip.....I know a few that have lost a bulb in the top section, so it almost seems logical that that is the case......
I myself would love the strip to be more evenly lit........
I even considered removing that pc. of plastic and running a neon light assembly down the entire strip....(the flexible kind)....
In the meantime, I'm content with the looks of my Piaa Extreme Whites...
Old Nov 8, 2004 | 03:32 PM
takuyaah's Avatar
haha..i hear you man..i think the plastic piece is most likely to block the loose bulbs..(i picked it up twice because of that thing...good thing i have skinny fingers) ...
04.5 black/willow 5at coupe | premium package
clear corners | mtec fog/clearance/corners
alumium pedals | black emblems | 20/35 tints
Old Dec 6, 2004 | 02:02 AM
imRACERX's Avatar
purple wedges?
hey anyone got the purple wedge bulbs for the clearance strip? i replaced my 4200K with the 6000k which has a pirplelish glow to it and thought they might match it well. what do you all think? RX
lil beezy
Lights
Nov 16, 2015 02:52 AM
SupermanGPS
Sep 19, 2015 01:42 PM
twentyeggs
Sep 11, 2015 03:58 PM
