Please help!!!!!!
Old Apr 13, 2011 | 10:53 PM
nofearg35's Avatar
Exclamation Please help!!!!!!
ok so im pretty new here and i have a 03 doggy door sedan and my license plate and front side marker lights dont work. the tail lights are fine and so are the blinkers and interior lights. i checked every single fuse and yes ive checked the infamous 3rd fuse box behind the battery and i even changed the "culprit" tail light fuse with a spare and nothingconfused. i just checked the right side marker and found a burnt bulb. now do i have to replace it to work? i would think that it would still light up the license plate and the driver side marker right?? any ideas anyone????
Old Apr 14, 2011 | 02:27 AM
Beebo's Avatar
just replace the bulbs
im a little confused by the way you stated your problem
Old Apr 14, 2011 | 08:36 AM
LEDmarkers's Avatar
All you need is new 194 bulbs orrr a retrofit from us
Old Apr 14, 2011 | 11:08 AM
nofearg35's Avatar
Ok so if I replace the bulb it should work??? But wouldn't think the right side marker and license plate light would work????
Old Apr 14, 2011 | 11:21 AM
DomeP1ece's Avatar
check all the bulbs ......
Old Apr 14, 2011 | 11:28 AM
TannerG's Avatar
Replace burned out bulb with good bulb. Location with good bulb will now light up when it is supposed to. Repeat at other locations with burned out bulbs.
Old Apr 14, 2011 | 11:47 AM
nofearg35's Avatar
Ok so I replaced the bad bulb and now the license plate lights up but still no side markers. The orange circle park lights never came on either but the license plate does work now
Old Apr 14, 2011 | 11:52 AM
nofearg35's Avatar
Thanks to all for the help by the way love this site!!
