G35 sedan grille help
Old Jun 21, 2011 | 09:01 PM
biggerandbetter's Avatar
Will a coupe grille work on a sedan? I just test fitted my stock coupe grille onto my sedan, and it seems like it all lines up fine. The thing that does not work is the tabs on the bottom of the grille, I would most likely need to shave them. the top pushtabs and screw holes are all the same and line up. Any tips would be awesome!
Old Jun 23, 2011 | 07:33 PM
Kooz's Avatar
I am also interested in knowing if the coupe grill would fit. might need some slight mods to fit the lower part.
you wouldnt want to try a diy with pics would you?
Old Jun 28, 2011 | 06:28 PM
ViciouS's Avatar
IIRC, the coupe grill doesn't fit certain models of the G. You should just check with the manufacturer to see if they sell coupe as well as a sedan option just to be sure.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
