FG front cracking through the paint???
I've never done fiberglass on any car I've owned in the past. I have the Strafe Nismo sedan FG replica with glassed in inserts. I've only had it on maybe 6 months. I'm noticing several cracks in the finish near the corners around the headlights, grille, and side markers. Is it normal for FG to behave this way? Is this a construction issue or is it a finish issue? It's never hit the ground going over bumps. I even use blocks of wood to get the car up high enough to not touch the ramps when I get her off the ground for maintenance(funny how a stock Z suspension can't clear low profile ramps for maintenance). Anyway, any thoughts?
