Modify front bumper
Old Mar 11, 2012 | 11:52 AM
G35RACR's Avatar
Modify front bumper
I need to know how and what to use to modify my front bumper on my 04 G35 coupe. What kind of clay or foam and where to buy it online. Any DIY videos would help. I've worked with carbon fiber before but never anything this scale. Thanks
Old Mar 11, 2012 | 12:55 PM
johnnydarko's Avatar
well.. lets start with what are your goals?
Old Mar 12, 2012 | 12:43 AM
G35RACR's Avatar
To make my own custom body kit
Old Mar 12, 2012 | 01:22 AM
Beebo's Avatar
Um fiberglass is your friend.... where are you from? a custom kit will cost a pretty penny...
Old Mar 12, 2012 | 02:50 AM
G35RACR's Avatar
I'm in CA. I've done carbon fiber projects and know that it's expensive but I need some info about molding the parts from clay or foam. Where to buy , what to get and some tips on how to.
Old Mar 12, 2012 | 11:31 AM
TunerMax's Avatar
G35
subscribed, post what you figure out, I'm planning on doing something similar. I don't really like any available options out there for the sedan, other than a stock 05/06 bumper. Which I may grab and customize to fit the 03/04. Probably be less work.
Old Mar 12, 2012 | 05:26 PM
BAUSauto's Avatar
You can use clay or foam but that's only for sculpting your plug.. from there you'll need to glass over the clay or foam and make it into a hard solid plug to make a mold out of.. finally the mold from your finished piece is going to be the one you want to put on your car.
For foam make sure the foam you use can withstand resin.. if not then a cheap trick would beo to duct tape over the foam and glass over that lol..
Old Mar 12, 2012 | 06:14 PM
TunerMax's Avatar
G35
^Good tips dude. I wasn't planning on making a mould, I was planning on just modding the bumper and that's it. Not sure what the OP's up to though.
I'm just intending on changing the vent setup essentially.
Old Mar 12, 2012 | 06:56 PM
BAUSauto's Avatar
Vents should be okay but If you're building a bumper from clay foam or bondo it won't last eventually crack or chip >.<
Old Mar 12, 2012 | 08:30 PM
BAUSauto's Avatar
scrolled through that..
Expect it to be as heavy as elephant *****..
Old Mar 12, 2012 | 09:26 PM
TunerMax's Avatar
G35
WTF on the e46 link. Who want's a 500 lb front bumper? I do I do!!!!
Old Mar 13, 2012 | 12:01 AM
TunerMax's Avatar
G35
Not mine, but maybe the OP will chime in with his intentions. mine will be a redo of the vents, and I may add a purchased lip. that'd be it. Nothing that will need a mould, or blocks of freaking wood, either, to be sure.
Old Mar 13, 2012 | 02:29 AM
Xx AzN xX's Avatar
dangg thats a heavy bumper -__-
