Q about tail light overlays
Old Apr 24, 2012 | 09:16 PM
Soilsample's Avatar
Hi guys
I'm awaiting delivery of my tail light overlays.
Do you guys remove the lights for installing overlays? Or do you do it on the car?
How diFficult is it to remove the tail light?
Thanks
Donald
Old Apr 25, 2012 | 01:07 PM
zjohnson1's Avatar
This is a general question that could easily have been found with a little searching. It would be wise to do that before starting new threads
Remove the lights, it'll be easier to manipulate and stretch the film. Only 4 screws holding the tail lights in once you get out the trunk trim, very easy to take out. Also be sure you've got a heat gun and sharp razor blade or you'll be hating life. Tuck the corners into the crevice where the lens attaches to the casing (red meets black) for the best finish.
Old Apr 26, 2012 | 02:56 AM
Mark2K8's Avatar
Remove them
Old May 9, 2012 | 09:09 AM
Therzdae's Avatar
Remove ^ 2x... in my opinion if you have never done overlay or tint you may way just pay someone to do them, its not easy. I consider my self very tech/mechanic savy and struggle with this art. I just sprayed my tail lights, and would always spray over overlay, although overlay saves your original color/surface.
But if you want pictures of nightshade done on one I have a few of mine.
Old May 13, 2012 | 02:43 PM
Rated-G's Avatar
when i install my overlay ..i didn't take out the tail light . its much easier to apply the overlay when the tail light is not moving or anything
Old Jun 12, 2012 | 08:09 PM
Ray@OCInfiniti's Avatar
I agree, even our installer leaves them on the car, it's SOOO much easier to work with.
the overlays will require heating and some stretching to fit correctly due to the curves of the light itself. It's easier to do this while they're on the car so you can put pressure where you need and not worry about them wiggling around.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Jnm07
Sep 5, 2015 01:16 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
