Speaker rings and small aluminum dash bar removal
Old Jan 17, 2013 | 04:54 PM
That's G's Avatar
Hi guys,
I'm in the middle of wrapping my aluminum trim in carbon fiber vinyl and I'm stuck as to how to remove a coupe pieces.
The first piece is the aluminum ring that goes around the speakers. Do I need to remove the door panel to pop them out?
The second piece is the small aluminum dash bar to the left of the steering wheel. It doesn't seem to pop out like the long one on the right does.
Thanks for your input.
Old Jan 17, 2013 | 06:09 PM
Frankieg35's Avatar
For the speakers remove the door panels and the slim piece on the dash I would try a thin screwdriver with tape on it to pop it out..
Old Jan 17, 2013 | 06:40 PM
OBsessed's Avatar
The small one on the left won't pop out, it's screwed in from behind. Two small philips head if I remember right. You have to remove the plastic dash panels on that side (don't go crazy, just start from the bottom up) to unscrew it.
Old Jan 17, 2013 | 06:41 PM
k67p67's Avatar
You need to remove the door panels to get at the speaker trim rings. They have plastic posts that are melted to the plastic door panel base. Use a heat gun to remelt the plastic and pull the rings off. Reinstall using the same method. The small horizontal trim piece to the left of the steering column is attached to the vent. Remove the underdash cover and screw that secures the vent to remove.
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
linedr89
Aug 17, 2015 05:11 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
