Door Sill Lights T-6
Old Feb 2, 2005 | 10:20 PM
truplay8's Avatar
THE BATMOBILE
Question Door Sill Lights T-6
hey i was wondering if anybody could give me a direct link to a BLUE bulb that will fit in the door sill............thanks a lot............ps. FLFIRE the map light 4 leds looks great......thanks
Old Feb 3, 2005 | 12:47 AM
G35Lin's Avatar
Multi-Spoked Mod
http://www.superbrightleds.com/cgi-b....27001&next=50
3022-2 LED Festoon bulb
2-LED Festoon Base Bulb
31x10mm 12 VDC
Select Color
$ 1.19
3022-4 LED Festoon bulb
30x10mm (1.181 inches long)12 VDC Festoon Base Bulb with 4 LEDS
Available in White,Blue,Green,Red,Amber and UV LED
$ 1.89
You can choose 2 led or 4 leds They shoudl fit fine!
Ed
Old Feb 3, 2005 | 10:37 AM
truplay8's Avatar
THE BATMOBILE
ed.........i have the 30mm in my map lights...........FLFIRE said that they only fit in the map lights...........so does the 31mm fit for the door sill light? thanks
Old Feb 4, 2005 | 05:38 PM
truplay8's Avatar
THE BATMOBILE
ed any suggestions???
Old Mar 10, 2005 | 05:26 PM
shetyamout's Avatar
the door light are DE3022 Pill (8mm x 28mm). were you able to find some?
Old Mar 10, 2005 | 10:57 PM
Sukairain's Avatar
I ordered the 6LED bulb from Superbright LEDs and they are not bright enough. The 6LED maplight also a waste of time. The only thing I'd use to replace the map/dome lights are luxeon 3W LEDs.
mike730
Jan 12, 2018 04:25 PM
RA081024
Aug 18, 2015 07:03 AM
avalino
Aug 6, 2015 01:42 PM
