Cover scratches with paint, touch up spray, procedure
Old Aug 19, 2013 | 08:54 PM
BabySkyline's Avatar
Hi guys,
over the years, and after letting some (unexperienced) friends, and back-then unexperienced me drive around with the beautiful car, it acquired some nasty scratches.
I have a few questions:
1. Attaching some photos to describe the damage (I know, it's pretty harsh), what would be the best approach to fix it?
2. There is something coming off on the side of the car, by the door, is that clear coat? How can I fix it? The previous owner has told me that he painted the door, due to minor damage.
3. After some research, I am considering to buy a touch up spray, primer, and clear coat for it. From my first question, how should I get started on it? What do I use? 800 grid sand paper, etc.? Automotivetouchup or Dr Color Chip for my purpose?
Or would it be better for me to get the whole thing painted at a shop? I can live with the damage, but I wanted to spare 40-70 dollars to "fix" it a little, a few hundred for a paint shop is too pricey as of now. Or are there jobs that can do it for cheap?
I know, it's a disgrace to have scratches like that. Color code is WV2, Diamond Graphite.
Old Aug 20, 2013 | 10:55 AM
Void's Avatar
Looks like he ran right over a curb stop a few times, however; im not sure if there is much you can do to fix this other than having the front bumper repainted which might cost a few hundred to be done right.
Old Aug 21, 2013 | 09:22 PM
That's definitely a way to fix it, but are there any cheaper alternatives that I can consider?
Old Aug 22, 2013 | 04:17 AM
Also, the last two photos, the coat coming off the door, how can I fix it?
Thanks
Old Aug 22, 2013 | 08:09 PM
Void's Avatar
If you want it to look right you would have to have each panel repainted individual, you might be able to have someone touch it up but it might not look very well.
Old Aug 23, 2013 | 04:38 PM
rsingerG35's Avatar
Only fix is to have it repainted. No amounts of touch up will make it look nice again. A body shop can probably re-clear the door if the base paint isn't damaged. As for the front bumper it will definitely need to be completely re-done which might cost 350-550 on average to repaint.
Old Aug 23, 2013 | 07:24 PM
Thanks for the information!
Approximately how much is re-clearing the door going to the cost, assuming the base paint isn't damaged?
I will probably get a new bumper in the future as I have too many dents on there. Where can I get an (maybe refurbished) OEM bumper that doesnt need to be painted?
Old Aug 23, 2013 | 11:20 PM
rsingerG35's Avatar
Not sure. You can search on here or a junkyard for a used one. Other option would be aftermarket or new one from dealership. No reason really why a good body shop couldn't fix it.
Old Aug 24, 2013 | 04:04 AM
Sounds good. Ill research about/find out what prices for used, refurbished, new from different places are in comparison to fixing it from different shops.
Thanks
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
derres
Aug 28, 2015 03:27 PM
rsingerG35
Accessories
Aug 27, 2015 10:40 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
