Windshield Washer Fluid Light Flashing
Old Oct 11, 2017 | 02:04 PM
Colin Blanton's Avatar
Whenever I’m driving and my motor goes past 4000 rpm it flashes and once it goes past like 5500 rpm it stays on. Any ideas or is my car just trippin. It’s an 05 G35 Coupe 6 speed
Old Oct 13, 2017 | 09:03 PM
saywat?'s Avatar
fill fluid?
Old Oct 15, 2017 | 02:56 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The float switch can fail just like every other component on the vehicle, ESPECIALLY if you or the previous owner has been using water in the washer pump reservoir instead of actual washer fluid (washer fluid won't corrode all the little metal parts). Might also be a bad gasket on the harness for the switch, I've never dug into it before but was just recently reading up on it. Remove the front bumper cover and the switch should be accessible.
Can you reproduce the problem in neutral? Take a picture of the dash if so.
