Part # Needed - '03 G35 Coupe Rubber molding for Mirror/Tweeter
Old Jun 21, 2019 | 03:09 AM
jutn35's Avatar
G35 Coupe
Question Part # Needed - '03 G35 Coupe Rubber molding for Mirror/Tweeter
EDITED 1/21/2020
Please post here if you know where to source the Sail Panel Weather Strip.
80832-AM800
80833-AM800
Old Jun 21, 2019 | 06:16 PM
jutn35's Avatar
G35 Coupe
Old Jun 21, 2019 | 06:31 PM
jutn35's Avatar
G35 Coupe
So this rubber piece has to be bought with the mirror .....
Old Jun 21, 2019 | 10:42 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'm drawing a blank, that gasket isn't even shown on that diagram, I don't think it's sold as part of the mirror assembly either though.
Old Jun 24, 2019 | 04:00 AM
jutn35's Avatar
G35 Coupe
Ya I was looking at the diagram as well . Maybe its not pictured in the diagram. But this is what the Dealership told me. Im still searching.
Old Jun 24, 2019 | 01:15 PM
cleric670's Avatar
BANNED!!!
I'm starting to suspect those sail panel seals are the same part on both G35 and 350Z, go down to Nissan and have them pull these part numbers and compare to your existing seal.
Driver side, 80833-CD000
Passenger side, 80832-CD000
Old Jun 24, 2019 | 01:16 PM
cleric670's Avatar
BANNED!!!
I know the angle is SLIGHTLY different on the 350Z but the rest of the dimensions look the same and it is flexible so I bet that's the part number they use.
Old Jun 25, 2019 | 03:47 AM
jutn35's Avatar
G35 Coupe
I'll go down this weekend to the dealers and try to get to the bottom of this and update this thread when i find out.
Old Oct 20, 2019 | 11:26 AM
Spitfire91104's Avatar
Any luck? Mine are slowly disintegrating.
Old Oct 20, 2019 | 05:03 PM
cleric670's Avatar
BANNED!!!
Never heard back from the OP but you could probably drive down to your local Nissan dealership and look at the part numbers I listed a few posts up. Should be able to just hold it up to your door and tell if it will work or not.
Old Dec 24, 2019 | 03:34 PM
jutn35's Avatar
G35 Coupe
Sorry, I forgot to update this.Life got busy. But I went to Infiniti showed them pictures and the guy said I had to buy a whole new mirror..... I Don think so. Based on the images here. they dont look to be apart of the mirror assembly.
Old Jan 20, 2020 | 06:56 PM
jutn35's Avatar
G35 Coupe
just putting this here for later use. I saw a user posted these same things before.
https://my350z.com/forum/maintenance...ail-panel.html
A closer inspection of those seals may reveal that they are dried and cracked, and need to be replaced. Here's the parts:
Driver's side............80833-CD000
Passenger side.........80832-CD000
https://conceptzperformance.com/item...2&p=303&page=1
Old Jan 20, 2020 | 07:14 PM
jutn35's Avatar
G35 Coupe
I believe this is the part we are all looking for
Old Jan 20, 2020 | 10:32 PM
cleric670's Avatar
BANNED!!!
Was this ever verified? I posted those same part numbers a few posts up but never heard back if they actually worked.
I did confirm with Infiniti that there is no part number listing for sail panel seals for the G35.
Old Jan 21, 2020 | 12:36 AM
jutn35's Avatar
G35 Coupe
This is what was relayed to me from my Dealer.
