Center cluster, (clock) blacked out , help ..
Old Oct 18, 2019 | 04:46 AM
G35+2=X's Avatar
Purchased car 2 months ago , used to have Acura TL/SH premium .
Bought the G in the summer , all is well , with winter approaching it gets dark early .
I find it irritating driving at night , no clock , temp gauges , fan controls etc.
The last car I had it was also electrical issue but $600 just for parts (sold)
I can go to dealer for over $100 per hour to diagnose.
Anyone else experienced this black out .
PS: Used to have time delay on headlights , now nothing 🤯
Old Oct 18, 2019 | 02:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's just the AC auto amp display and clock that doesn't have any display correct?
The AC does WORK properly though yes? And you can cycle through all the various vents, fan speed, etc. You just cannot SEE INFORMATION on the AC display?
If so then you probably just need another AC display, if it's actually not FUNCTIONING then you might need the AC Auto Amp replaced.
Check fuses 6, 12, and 19 in the Fuse Block - J/B in the left side footwell fuse panel. They're all 10 amp fuses.
Old Oct 18, 2019 | 02:45 PM
cleric670's Avatar
BANNED!!!
Time delay on the headlights is a BCM function but it requires the dealership Consult - II tool (or some 3rd party ones that can do CAN functions I think) to change it.
The delay only works if you leave the headlights in AUTO mode though, if you turn the headlights off with the switch then they're off, no delay.
mtbank
Dec 10, 2017 05:57 PM
jdubin94
Feb 8, 2012 01:12 PM
Als35
Aug 18, 2007 11:04 PM
johnzg35
Interior
May 28, 2003 08:08 PM
nepog3
Lighting
33
Jan 20, 2003 04:31 PM
