clear corner bulbs
Old Mar 8, 2005 | 09:53 PM
neal540's Avatar
clear corner bulbs
I saw that one of you guys used the piaa super wedge 19263 for the coupe. can you use any of those series, and if you can, does anyone have pictures? also, i want to replace the bulbs in the strip light. what would they be? same thing?
thanks,
neal
Old Mar 8, 2005 | 10:41 PM
Dj Cyntex's Avatar
Yea, the bulb you use in the clear corner is the same as the bulb you use in the clearance strip.
Old Mar 9, 2005 | 12:32 AM
BombRush's Avatar
Anyone have DIY for how to install clearance strip lights??
Old Mar 9, 2005 | 01:41 AM
Dj Cyntex's Avatar
What I did was turned the wheel all the way inward then popped out the tabs and unscrewed the wheel well.. Pulled the well back and reached in to find where the light was. Pulled the bulb out and replaced it. Took maybe 15 minutes for both bulbs. Pretty easy.
Old Mar 9, 2005 | 06:36 AM
skeleton_cru's Avatar
Sedan
Hey did you try the DIY forum???
lil beezy
Lights
Nov 16, 2015 02:52 AM
SupermanGPS
Sep 19, 2015 01:42 PM
twentyeggs
Sep 11, 2015 03:58 PM
