Just wondering if the fogs can be wired to come on separatly from the headlights....Or maybe to always come on like daytime running lights?? Anyone know?
I saw a 03 or 04 with canadian plates that had their fogs on but not the headlights...I know in canada its the law to have daytime running lights so Im just wondering.
To do this, you will need to find the relay to the fogs. After locating the relay, find the wire that triggers the fog relay. Next, use a +12V switched (ign, not acc) to trigger the relay. After that your fogs will turn on and off with the ignition.
Quote:
I'm also interested in this mod.......Where is the relay for the fog-lights does anyone have a picture of it?Originally Posted by hgiljr
Anyway of connecting them to the park lights? If so any how too manuals out there?
Can it be possible to have the fog-lights on with the parking lights. Is there a how-to? With detailed instuctions
i tried...
stupid infiniti used the bcm to control everything...
Here's how it goes-> switch to the BCM-> to the IDRM -> to the fog relay-> to the fog lights.
kpierson programmed a unit to hook up to the BCM so you can utilize the fog light switch to control the relay.
There's no other way around it.
I thought KP was working on a commercial solution for this... just wait a while or contact him. If it's anything like the rest of his "magic", it'll be worth the wait.
http://www.kptechnologies.com/
