Painted my Engine cover
Old Jun 30, 2005 | 11:31 PM
shipsaeki's Avatar
I did this DIY a while back, but never got around to posting it. I no longer have it on the car, I have a CF one, but I'm curious to what people think.
I kinda messed up masking, i may repaint it just for the hell of it.
Tell me what you guys think. (Sorry, don't know how to reduce pic size)
Old Jun 30, 2005 | 11:47 PM
imalazeeass's Avatar
nice. what did u use? just spray paint?
Old Jun 30, 2005 | 11:49 PM
shipsaeki's Avatar
yeah, just used regular spray paint. forgot what kind it's been so long, i'll post what kind of paint it is tomorrow. It held up good... no problems with heat. only thing is it gets dirty too quick.
Old Jul 1, 2005 | 08:40 AM
Wicked_limitz's Avatar
looks pretty good.
Old Jul 1, 2005 | 12:56 PM
jdbinspired's Avatar
Looks Really Good from that angle...
Old Jul 1, 2005 | 01:24 PM
FrizzleFry's Avatar
did you put a clear coat on it as well? we rattle canned an engine bay and did 2 coats of clear on it and it looks stunning.
Old Jul 1, 2005 | 01:27 PM
cutiewolf's Avatar
can u post up a DIY that would help us alot and save some bucks!! thanks!!!
Old Jul 1, 2005 | 08:14 PM
shipsaeki's Avatar
yeap, I put clear coat on it... it looks pretty good in person. Only thing that sucks about white, it gets dirty too quick.
It's pretty much straight foward.
1. take off engine cover by removing 2 10mm bolts, and 2 10mm nuts.
2. mask the area you do not want painted.
3. use like 1000 grit sand paper and scuff up the area you do want painted.
4. spray the cover in primer. use light coats from about 12-16 inches away from the surface. remember to use light coats or else it will drip. use light coats... about 4 coats should be fine.
5. let the primer dry, and then use 2000 grit with water to wet sand out all the imperfections and highspots.
6. after wet sanding, dry off all the water and use prepsol or paint thinner to remove all the oil from the cover your hands may have left.
7. same as the primer, use light coats of spray paint. if it drips, it will look like crap.
8. after about 4-5 coats, let dry and then use clear coat. again, use about 5-6 coats of clear. do not let it drip.
9. let the clear coat dry for about 4 hours and your ready to put it all back together.
10. enjoy a nice cold beer while you sit back and look at your work and enjoy!
hope that helped.
Old Jul 2, 2005 | 02:12 PM
S-Tuned's Avatar
gtr proto test driver
what cf cover do you have?
Old Jul 2, 2005 | 02:21 PM
CarFanatic56's Avatar
that looks cool
Old Jul 2, 2005 | 03:39 PM
shipsaeki's Avatar
UTR cf cover.
Old Jul 5, 2005 | 09:49 AM
mark5's Avatar
what's up man, I think I'll be stoping by Park ave soon, window rattles driving me nuts
Old Jul 5, 2005 | 10:20 AM
G35_coupe_6MT's Avatar
IMO it would look better if you paint the rest black. Somehow, mask the V6 thing and paint the thing black with the white border you have.
Old Jul 5, 2005 | 06:38 PM
shipsaeki's Avatar
sure np... who are you tho? Sorry I'm bad with matching up names. what car do you have?
Old Jul 5, 2005 | 08:12 PM
truplay8's Avatar
THE BATMOBILE
looks great.........good work
