HELP!!Question about Greddy Bumper!!!
Old Jul 6, 2005 | 04:38 AM
Drift Mania's Avatar
Currently I have the Greddy bumper on my car, just want to ask is it easy to take it off by myself and how do i do it? Need to do this before Sat.
Old Jul 6, 2005 | 03:46 PM
truplay8's Avatar
THE BATMOBILE
are you selling it??? why are you removing it?? if so i would be more then happy to take it off of your hands
Old Jul 6, 2005 | 03:50 PM
ducatiguy's Avatar
Premier Dough Slapper
Yea its easy, but theres more to it..... You will need to access two sets of 10mm bolts (with philip screw heads) that are behind the corner lights. To do so you need to remove (just enough to get behind there, usually the first three push pins) the inner mud / splash guards from both sides. You can then access the two bolts that hold the bumper to either side. Once removed, you can then lift open the hood and remove the front grill (just makes things easier) by once again by means of push pins and two 1/4 turn screws on the far end corners (accessable through the grill itself). You will then have two push pins holding down the top portion of the bumper. Once removed, you will have to get to the bottom of the bumper and remove a few 10mm bolts, and off it will come. On average I can do everything I've mentioned above in under 30min, but then again I've done it several times. One suggestion, if you're working alone is to get a blanket or large piece of cardboard and place it below the bumper, this way you wont scratch it in the event one end falls down or you need to move it around a bit getting it off or putting it on.
Old Jul 6, 2005 | 07:57 PM
THanks, the reason why I have to take it off is because I am going to a Drift Session this weekend, so I'll have to take it off at the track. I am worry I'll hurt the bumper. That's why!
Old Jul 6, 2005 | 08:48 PM
ducatiguy's Avatar
We should have know, after all with a name like drift mania - its only natural thats the reason - lol... Anyhow, I hope you have something else (OEM bumper) to put on its place, otherwise you're going to have the bottom engine cover slapping away (as it has nothing to mount up to with the bumper off). Last but not least, we expect some pics from your drift session!
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
Th611
Oct 27, 2015 03:48 PM
Tukeeg35
Sep 27, 2015 12:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
