need help fast~!!!!
Old Jul 7, 2005 | 11:32 PM
davidchoi425's Avatar
Question need help fast~!!!!
does n/e one know how to take this star bolt out from the trunk bracket? i got the top two off but i can't seem to take the botom two... i need help fast~!!
Old Jul 7, 2005 | 11:42 PM
ducatiguy's Avatar
Premier Dough Slapper
Trunk bracket? Star bolt? What are you doing? Which bracket? What bottom two? Are you working on a coupe or a sedan? If it's a "star" bolt, you probably mean either a philips or torx bolt, and if so my only answer would be to use a philips (star) screw driver / bit or a torx driver / bit. A little more detail in what you're doing, trying to remove, install, work out or whatever would help us provide you with the right info...
Old Jul 8, 2005 | 12:24 AM
i'm trying to install my c/f trunk lid on my coupe. and i need to take the four screws thats on the trunk lid... and it a star torx... i can't take this out...i give up... i almost stripped the bolt so i decided to take it to the professional. body shop should be able to do this rite?
Old Jul 8, 2005 | 01:11 AM
ducatiguy's Avatar
Ahhh ok, that's an easy one... You need a torx bit or driver. I can't recal if I had torx heads on mine when I swapped my trunk with a carbon fiber one, but I've since replaced them with 10mm bolts. Much easier to work with...
I guess the only suggestion I can make for you now that you've stripped them, is get a drill and drill bit (big enough to cover the center section of the "star area" and drill out the bolt heads. Just be sure to keep the drill centered and the heads will "drill off". You can then pull the lid off and remove the bottom end of the "headless" bolts (struck on the OEN lid) with a pair plyers or vise grips. You now will need new bolts, so take a ride to the depot or your local hardware shop and pick some up.
Good luck with your project....
Old Jul 8, 2005 | 01:57 AM
thanks... i haven't completely stripped the head yet... i'll give it a try again tomorrow.. hope this will give my ride a different look and shave off some weight. i'm don't wanna go on a diet so i gotta put my car on a diet.. ahahaha....
Old Jul 8, 2005 | 02:36 AM
dennis_said's Avatar
I remember when I did a trunk swap that it was possible to remove the trunk w/o messing w/ the screws at all, you just UNLATCH the SHOCK/DAMPENER... and PUSH DOWN REALLY HARD TO release the trunk lid
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
magnetism80
Jan 27, 2016 12:57 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
