replacing map lights, license plate light, door sill lights
Old Sep 22, 2005 | 04:08 PM
njg356mt's Avatar
Anyone know the easiest way to swap out these lights? I dont want to just pull and break stuff
Old Sep 22, 2005 | 04:31 PM
truplay8's Avatar
THE BATMOBILE
its all in the manuel.........................map light- use a flat head screw driver and pry the covers off. License plate light pull the sides in and pull down, twist off the light cover and change the bulbs. Door sill lights, pry off the plastic cover and change them.........its pretty basic.....good luck
Old Aug 22, 2009 | 05:07 PM
LakeShore_Slate's Avatar
i couldnt find anything on the 07 sedan replacing the license plate lights, is it the same? I found it! yeap it is!
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
crazy_g35s
Jul 20, 2015 02:30 PM
