Debadging Rear Infiniti Logo
Old Sep 29, 2005 | 08:00 PM
OCG35's Avatar
Originally Posted by g35togo
Quick question... Where,and how much for black chrome logos and/or numbers and lettering
I use Rick at 24 KT. Gold Plating (he does black chrome too): 714-328-9810 (is mobile)... good prices, quality pieces. I have done several pieces and used him each time.
Old Oct 5, 2008 | 06:31 PM
G-Kid's Avatar
does the infiniti logo on the back of the car have that adhesive stuff on the back? or is that on with screws?
very important, i dont wanna screw up my ride because of a stupid mistake
Old Oct 5, 2008 | 06:42 PM
Beebo's Avatar
on the coupe it just has the tape on the sedan there are holes... Please search
Old Oct 5, 2008 | 07:30 PM
OCG35's Avatar
there are no screws or bolts - as stated above the sedan has two holes, but that’s just to lines up emblem... there are two small pins on the back of the sedan emblem that slid in the hole.
The emblem attached with 2-sided tape (something specifically for auto emblems and trim - 3M is what I use)... If you are rebadging with a set that has been black chromed (or whatever else) you'll need to apply the tape yourself. If you are applying a new set from the dealer they will already be taped.
Make sure you use a "sedan" emblem - since the coupe one has no pins (for the holes) and is a tiny bit smaller.
The letters are all two-sided tape only. I'm not sure if the coupe and sedan sizes are different - they might be since the sedan trunk is bigger (so make sure you order for sedan, in case they are different sizes).
As beebo said above, you can search for ways to remove and apply... if you have questions, ask away - that’s what the forum is for.
Happy modding
Old Oct 5, 2008 | 08:20 PM
G-Kid's Avatar
ok so let me make sure im getting this all, i shouldnt have a problem removing the logo? i know the letters will come off smoothly i just want to make sure the logo will as well
Old Oct 5, 2008 | 08:32 PM
OCG35's Avatar
yep - the logo is applied on the same way... it just takes a little more effort since its bigger... heat it up a bit and remove gently and slowly... some people like using fishing line or dental floss to slide behind... I just use a hair drier to soften the adhesive and gentle pry them off with a thin plastic squeegee and my fingers.
Its good to let it sit in the sun for a few hours to help the process.
Old Oct 5, 2008 | 09:19 PM
gizmo134's Avatar
ive got pics of an 05 sedan thats fully debadged
Old Oct 6, 2008 | 10:52 PM
Beebo's Avatar
Is it yours? The holes behind the emblem had to be shaved
Old Oct 7, 2008 | 01:31 AM
gizmo134's Avatar
it is, but when i bought it it was like that. i actually bought it from a member of the forum, neil376. its an 05 sedan, and from what i remember hearing it wasnt an easy task debadging it. it came out really nice tho
Old Apr 16, 2012 | 02:21 PM
brew2012's Avatar
Re: Holes behind Mt. Fuji Logo
I just debadged my 2007 g35x. All coupes have no holes behind mt. fuji badge. Sedans have holes from 2003-2006. 2007 and newer, no holes.
I have no ghosting. I used hair dryer, fishing line (dental floss breaks), Goo Gone in small intervals followed by 50% rubbing alcohol and 50% water. The Goo Gone will haze the clear coat if you apply too long without neutralizing with alcohol/water mixture.
The letters all were simple to remove without evidence, but the mt. fuji emblem take care with. I had a friend help me, we went in steps.
Wax after with a hand wax. Should be good.
rezendvous420
May 31, 2020 01:26 PM
tiguy99
Mar 1, 2016 11:42 AM
neight
Aug 3, 2015 11:27 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
