installin wedges
Old Oct 7, 2005 | 10:56 PM
Jtrain's Avatar
installin wedges
turn your steering wheel completely to one side and remove the "fender well". i think there are about 6 or so of those button clips...
bend it out, towards you and stick your hand in there to find the bulb... replace.
Found that off search [woo goo me]
Cut my finger up pretty good trying to remove the "button clips"
I see 3 of them on each side- im assuming that im trying to remove the right ones...
How in the hell do you take them off!?
Old Oct 7, 2005 | 11:39 PM
afr0puff's Avatar
Supa Dupa Moderator
And this belongs in the Coupe forum because?
Moved.
Old Oct 7, 2005 | 11:48 PM
Jtrain's Avatar
Because its a coupe.. I dunno-- my bad.
Old Oct 8, 2005 | 10:28 AM
Jtrain's Avatar
/bump out of frustration =\
Old Oct 8, 2005 | 12:03 PM
PeteNJ's Avatar
You honestly can't figure this out?
Old Oct 8, 2005 | 12:16 PM
Silverbolt's Avatar
Are you talking about your clearance lights? What I do is remove the three little pop screws off from the wheel well. Go under the hood and push the plastic wheel well out and give yourself room to work behind the headlight housing. Just reach back there and change your bulbs. No need to go in from behind the fender.
Old Oct 8, 2005 | 04:15 PM
vstypicals's Avatar
LOL. He doesn't know how to remove the clips. Wow..
Old Oct 9, 2005 | 12:12 AM
Jtrain's Avatar
LOL. *****
Old Oct 10, 2005 | 02:52 PM
Triple8Sol's Avatar
get a flathead screwdriver bro...
thewarden
Aug 30, 2015 04:00 PM
pdjafari
Jan 4, 2006 11:14 PM
StatikTLR
Feb 18, 2004 12:16 AM
drsifu1
Lighting
29
Oct 22, 2003 09:07 AM
