Turn signal for 03-04 sedan
Old Dec 2, 2005 | 07:21 PM
godmans's Avatar
does anyone know how to make the turning signal of the 03-04 sedan light up (when the headlight is on) like what the coupe or 05+ sedan have?
i know there is a side marker blinker mod.. but i couldn't find anything on lighting the turn signal up
regards
godmans
Old Dec 2, 2005 | 07:41 PM
avs007's Avatar
regards
godmans
I don't think it's possible, because in order for em' to light up with the headlights, you need dual filament bulb, wheras the regular bulb/socket is single filament, so I don' think it will be an easy mod.
If you wanted to play around with diodes you could probably jury-rig a setup, by splicing into the clearance strip. Does the sedan have a clearance strip? (I have a coupe, so I don't know).
Old Dec 2, 2005 | 08:19 PM
godmans's Avatar
first of all, please bear my ignorance.. i dunno that we need dual filament for the bulb to light up and blink at the same time..
Secondly, sedan doesn't have a clearance strip..
and i am just curious if it is doable since 05 has it ..but not 03-04
godmans
Old Dec 5, 2005 | 05:45 PM
ttrank's Avatar
Grocery getter
I know how to do it by adding a couple of relays but there was a post somewhere that told how to do it without any relays. Let me see if I can find it.
Muski_G
Dec 1, 2023 11:11 AM
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
neight
Aug 2, 2015 03:01 PM
teamghost
Jul 28, 2015 04:52 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
