Replacing Fog Light Bulbs
Old Jan 12, 2006 | 10:23 AM
e420x's Avatar
Mod Junky!
I am thinking about replacing the fog bulbs with a yellow bulb or atleast a whiter one then teh stock. Is it a pain to replace the bulbs? Do I need to remove the bumper or anything off the wall like that?
Old Jan 12, 2006 | 10:41 AM
crypten's Avatar
If anything is to be removed to access the fogs, it would be the wheel. I did it without removing the wheel, but cut my hands and fingers up. You can just remove the inner lining, pull it back, and then you can access the fogs. If you have huge hands I wouldn't recommend it.
Old Jan 12, 2006 | 11:01 AM
twitch's Avatar
It's not necessary to remove the bumper.
Give yourself some time because it's more involved than it should be to change the bulbs but it's not hard.
Use the search feature and you can find some info. Here is a decent thread that should get you the information that you need -
https://g35driver.com/forums/faq-diy/56-changing-fog-light-bulbs.html
Most of the pictures do not come up but you really don't need them.
Good luck.
Scott
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
attarday
Jul 15, 2015 04:03 PM
