Clearance Light Install
Exterior Modifications ; Interior Modifications ; Lighting ; Gauges and More
Jan 14, 2006 | 03:23 PM
Steelz
Jan 2006
Can anyone tell me the easiest way to install the clearance light bulbs?
Steelz
Find all posts by Steelz
Jan 14, 2006 | 05:06 PM
G35MR2
Mar 2005
Philly Burbs
turn the L or R wheel completely to one side and remove the inner fender lining. Then twist and pull the harnness out of the socket. Hope that helps.
G35MR2
Find all posts by G35MR2
Jan 14, 2006 | 05:10 PM
donot521
Feb 2005
Vancouver, BC
just open up your hood, and try to squeeze your hand in there and get the thing out.....if you have a big hand.....then try the solution above
donot521
Find all posts by donot521
03 Sedan, Help with Starting Problem
chinee
Jun 10, 2024
07:48 PM
Projector retrofit on 06 g35 sedan
Jusseth
Sep 13, 2020
12:25 PM
Cam installing
Ashton35
09:19 PM
Valve clearance
Ashton35
10:11 AM
Headlights problems
attarday
04:03 PM
Back to Subforum
View Next Unread
INGS Face Ducts!!! ***Look Here***
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
08:51 PM
