Any one installed their Own Body Kit?
I just got my ING+1 Full Body Kit replica, a couple of my friends said that all I have to do is get the Kit painted and just install the kit my self. I'm just wondering how hard is the install on our Coupe? If you have any instruction I'll appreciate it, or should i just pay the shop to do it?
I would pay and have a good bodyshop do the job. Good luck though on the install. post some pics of before and after. If you do the install yourself, please let us know how is goes as well.
its all bolts.. not too hard of an install from what i've heard.. theres a few members here thats done their own install.. see if they drop a hint or two on installing
BUT your kit is a replica so i suggest you taking it to a shop since they'll be able to use different bolts and washers to make everything fit.. alot more convient for them to do it then for you to go to home depot and scouting everything out
My thought on this is that the install cost is going to be minimal, especially compared to the cost or prep/paint. Why not spend the $50-$100 and have it all done when you pick the car up? Otherwise, you're looking at having to transport the part back home, which runs the risk of scratching it. At least ask how much they'll charge to put it on.
A benefit of letting them do it, besides being able to avoid scratches, etc., is that they know all of the little tricks to get body parts to fit as perfectly as possible.
Yap, I'll most definitely ask them how much to install but since I'm from NYC price for labor here are high. I'll probably let them install it if it's below 200, I"m not sure if it cost above 200 that's why I'm preparing my self if I'll be able to do it my self.
what i would recommend is this.... when you kit arrives, test fit it yourself to your car. it's just a bunch of phillips head screws and 10mm bolts holding everything together. bolt the kit onto your car (right outta the box, unpainted and unprepped) and see how everything fits. if it fits to your satisfaction, you can have the bodyshop just paint it right up and then install it yourself... if not, then you know it needs some work by a shop to make it right
if you need recommendations on a shop in our area, hit up the G-Squad forum and post up.... you'll get lots of responses
That's a great idea....can't wait for my kuruma to come in. Gotta figure out how to take off the front bumper though
any threads on this? Tried a search....
Originally Posted by SI_G35Coupe
even AUTHENTIC kits require at least some prep and finessing to make them perfect. with a replica body kit the chances that something won't line up exactly right are even greater. i had a friend of mine pay close to $1600 to prep, paint, and install a replica bodykit on his G here in NYC. the majority of the price comes from the prep and painting..... sometimes fiberglass parts need to be sanded, bondo'd, shaved, or otherwise tweaked to make sure they're fitting just right. this is not something i recommend doing a DIY with a replica kit
Any shop you recomend in SI? I'm from the Island Too.
