I am removing my INGs FACE DUCTS today, please advise on process!
Old Mar 26, 2006 | 12:27 PM
dennis_said's Avatar
Question I am removing my INGs FACE DUCTS today, please advise on process!
I am removing them only to put them back on, I didn't install them properly the first time (put the adhesive too far back so the front isn't flush)
Any advice on removal? My biggest fear would be cracking it, I have a GRIP of 3M adhesive on there too =T
I was figuring just use a hairdryer and go slowly?
Old Mar 26, 2006 | 01:10 PM
truplay8's Avatar
THE BATMOBILE
pics pics pics........ask silverbolt for advice or search his thread that shows his progress during install
Old Mar 26, 2006 | 01:18 PM
ONEmike's Avatar
is it urethane or fiberglass. if its fiberglass use a blowd dryer and hear up the spots where the tape is then use chicken wire or fishline and slowly run it through the spots where the adheisive is
Old Mar 27, 2006 | 06:05 AM
Rookie84's Avatar
It is fiberglass so go by ONEmike's recommendation. If you have a heat gun, it'll make everything go so much faster because heating up something that large with blow dryer would be big PITA.
Old Mar 27, 2006 | 02:37 PM
pdjafari's Avatar
or you could always pee on them
Old Mar 27, 2006 | 07:36 PM
Silverbolt's Avatar
LOL, yeah, the acid would eat up the glue
Acutally a blow dryer does a decent job of heating it up. I had to use a blow dryer to heat it up to help reshape it to fit with my molded lip. I'd say, hit it with a blow dryer or heat gun, and just slowly take it out. Work your way from one side to the other. I'd probably try and remove the botom first, and the top afterwards... all because of the angle. Good luck, and be careful
skippyG
Jan 25, 2016 01:18 PM
RA081024
Sep 7, 2015 01:29 AM
linedr89
Aug 17, 2015 05:11 PM
Jussaku
Aug 4, 2015 12:45 PM
