D side power outlet
Old Nov 7, 2003 | 02:49 PM
nuttyprof's Avatar
D side power outlet
is it true there is no power to the driver side power outlet? i dont remember ever using it, except to light cigarettes...so im not sure. gonna try it later. if its true, is there a way to change it?
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Nov 7, 2003 | 04:36 PM
ryoken's Avatar
Re: D side power outlet
If it can light a cigarette, it's got power.
Old Nov 7, 2003 | 04:54 PM
SoCalTed's Avatar
I ran into this yesterday while trying to connect my Varad LEDs using the "power" to the lighted ring around the driver side cig lighter. I didn't bother checking to see if it was lit prior to popping it out, but now that I look back on it, I don't think that bugger ever lit up. Once I got the cig outlet popped out, I pulled the outer bezel light ring and tested the wire leads with a meter and got zero. Tested the wires to the back of the lighter and got a solid 12v.
I just soldered two wires to the hot and cold terminals at the back of the cig lighter and ran them to a block under the dash. Now that block servers as my "switched" power connection.
-Ted
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
CLICK HERE FOR MODS - COMMENTS ALWAYS WELCOMED
Old Nov 10, 2003 | 09:23 AM
cato's Avatar
SouthernComfort Moderator
I power my passport 7500 from the drivers side power outlet
every time I drive the car.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
DB/GroundingGear red 12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
