Help! Headliner falling down!
Old Jun 21, 2007 | 05:28 PM
nighttimeg35's Avatar
Exclamation Help! Headliner falling down!
Anyone know a good way to fix this issue? My headliner looks as if it is falling apart where it had been stitched or glued to the area right around the back of the moon roof.
Does anyone have any answer to this? Or, has anyone else had a similar problem, and how did you fix it?
Thanks. 2003 sedan.
Old Jun 21, 2007 | 05:49 PM
kyazh's Avatar
I have a sedan with the same problem. The headliner comes out of the rubber liner. Its because the liner is tos thin, it should have been at least 1/2 an inch wider. I just tuck it back under, and gets pretty freakin annoying.
Old Jun 21, 2007 | 05:59 PM
I'm trying to sell the car. Is there any quick fix you can recommend?
Old Jun 23, 2007 | 07:43 PM
kyazh's Avatar
glue? Epoxy maybe, between the roof and headliner and then put the rubber liner back on and use a credit card to slide the fabric in the liner...
SuperSaiyan
Sep 23, 2015 06:13 PM
Detailed Image
Sep 22, 2015 02:26 PM
