how to remove the rear door panel...
Old Feb 26, 2008 | 12:48 AM
reconJDM's Avatar
Hi I am new at asking questions,
was wondering if anyone know how to remove the rear door panel on the g35 sedan? I already unbolted the screw by the d00r handle, and somewhat remove the lower portion of the panel, now I'm stuck, because that plastic piece by the door handle won't nudge or come out easy.
anyone got any suggestions?
Thanks
Ryan
sorry if i didn't search, I usually do.
Old Feb 26, 2008 | 08:44 AM
lexusk8's Avatar
You need to remove the plastic piece on the door handle. It is held on by clips. To remove, use a flathead and start prying at the bottom end of the handle, then work your way to the top. Once removed, there are 2-3 Philips screws that need to be removed. From that point on, you should be ready to remove the door panel.
Old Feb 26, 2008 | 01:33 PM
reconJDM's Avatar
thanks a lot dude, those are some helpful tips .
jsimonk
Dec 22, 2023 03:49 PM
tiguy99
Mar 1, 2016 11:42 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
