Power outlet not working
Old Sep 8, 2008 | 01:31 PM
Logic25's Avatar
Whats up guys? I have a 03 G35 sedan which I love. The only thing is that lately the power outlets (passenger side and center console) are not working but my cig lighter is. I've checked the fuses inside the car and they're all good. I'm not sure where else to check.
I am hoping that someone has had a similar issue and was able to resolve it without going to the stealership.
Thanks
Old Sep 8, 2008 | 09:11 PM
ttrank's Avatar
Grocery getter
You can check the plug on the back side.
Are your dome lights working? I believe that plug has a different fuse but am not sure where it is located. There are two other fuse boxes under the hood by the battery.
Old Sep 9, 2008 | 11:31 PM
Logic25's Avatar
Yes the dome lights are working. I 'll check the fuses under the battery. When you the plug, that means that I would have to take the dash off to check if it is connected? I hope not cause that would really suck.
EnCr1pt3d
Jul 29, 2015 03:35 AM
beevanhuynh
Jul 14, 2015 09:06 AM
