Drivers Side door wont unlock
Old Nov 26, 2008 | 12:51 AM
jonesy's Avatar
I can lock and unlock with the key, but not the button inside or the remote?? Any suggestions?
Old Nov 26, 2008 | 12:55 AM
Gfast's Avatar
i have this problem before, the door actuator is broken.
if u still under warranty than the dealer will fix it for free
or u can search for some diy and fix it urself.
i remember seeing a thread about diy fixing door actuator
good luck with the repair
Old Jun 8, 2009 | 12:14 PM
realgone's Avatar
Widdle ya into kindling
I am currently having this problem, but have noticed it only happens when it has been sitting out all day in the sun and heat. It works fine when parked in the garage. Explain that.
Old Jun 8, 2009 | 12:46 PM
yourdoinitwrong's Avatar
Mine was an intermittent problem too. I had the lock actuator replaced and no more problems. It was covered by an extended warranty but if I remember right the cost would have been around $250 for parts and labor without it.
Old Jun 25, 2009 | 02:20 PM
cpufreak3's Avatar
EXACT SAME PROBLEM!
What year is your car? I asked this and no one can explain the reason. Probably the actuator, but I don't want to pay that much since I'm out of warranty...
Old Jul 14, 2009 | 05:21 PM
bocatrip's Avatar
It's the actuator. Usually covered under warranty. Out of warranty will cost between $300-$400 at dealership, cheaper at an independent shop.
Old Jul 14, 2009 | 11:48 PM
alfhasg35's Avatar
my dealer wanted $673 to fix the passenger side...
Old Jul 19, 2009 | 01:14 PM
bocatrip's Avatar
Sounds alittle on the high side. Are you still able to get an extended Elite Warranty?
Old Jul 20, 2009 | 09:39 AM
That's insane! Like my post above said my dealer was about $250 for parts and labor and they definitely don't discount anything.
Old Jul 22, 2009 | 11:58 PM
alfhasg35's Avatar
that's what it was...
elite warranty..?
i phoned the dealer and the finance guy never called me back..
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
apintojr
Jul 23, 2015 10:52 AM
emorehs
Jul 17, 2015 09:45 AM
