G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Interior (https://g35driver.com/forums/interior-176/)
-   -   Problem with driver's seat (https://g35driver.com/forums/interior/294865-problem-drivers-seat.html)
bobm-mass Jun 26, 2009 03:02 PM
Seat is all the way back. If you try to move it forward, the left side moves forward, but the right side doesn't, so the seat pivots to the right. The dealer said the entire left front seat adjuster needed to be replaced for $1400. This seems extreme for what appears to be no more than a jammed seat track. Has anyone seen this problem and repaired it?
bankerp1 Jul 3, 2009 05:12 PM
I just had mine fixed by a mechanic friend. I had same exact problem. The plastic gear in the seat track on the right side was wore out. This sounds like your problem too. A parts house wanted $900 for new replacement hardware which is basically the whole mechanism under the seat including the 3 motors. I was able to find used hardware from a salvage yard with a 1-yr warranty. Only the tracks with the gears imbedded were replaced. Mechanic left the rest of the hardware intact. Now I have extra motors incase I need them. Cost for the mechanism was $361 which included the seat bottom with attached hardware & a 1-yr warranty. Once fixed you have to turn the ignition to the on position until the airbag light goes out, then turn ignition off. Repeat this 4x total otherwise your airbag light will blink.
marty315 Jul 26, 2009 02:27 AM
I'm having the same issue right now. Anyone know how long the warranty from the dealer will cover this issue?
© 2026 MH Sub I, LLC dba Internet Brands
