Heated Seat Switch Light Out
Old Dec 21, 2009 | 04:49 PM
KuStOm101's Avatar
What's up fellaz, Iv'e got a quick question, I just picked me up an 04 g35 coupe, and a week later I realized my driver heated seat switch light is not eluminated at night as the passenger one is, does anyone know if you can just pop out the switch and replace the bulb that way, or do you have to remove the whole center console to get to the bulb, hopefully someone has had this issue before? thanks.
Old Dec 23, 2009 | 11:13 AM
KuStOm101's Avatar
anyone?
Old Dec 23, 2009 | 11:42 AM
pulse223's Avatar
Mine is like that too for most of the time (it lights up whenever it feels like it)
here's a link to sliderg35's heater switch mod thread. Pics are there~
https://g35driver.com/forums/interio...-mod-pics.html
Old Dec 23, 2009 | 01:03 PM
KuStOm101's Avatar
thanks for the reply but that's not the answer to my question, I have seen his post but I am not looking to MOD my lights, I just want to replace the bulb that has went out, what I am asking is to replace the blown light, can I just pop out the switch or do I have to remove the whole center console, the guys MOD post doesnt explain how he got to the light switch, thanks
Old Dec 23, 2009 | 01:19 PM
GR6RR's Avatar
if you push down on the button a little harder than flickin the switch.. itll pop down...
lift your center console where the switch is, and you can take the switch out thattta way.. and follow the steps on the link (Heater Switch Mode - Pics) the one above... to replace the light..
Old Dec 23, 2009 | 01:22 PM
KuStOm101's Avatar
Ok, I understand when you say push the switch down until it is able to be popped out, but I don't understand when you say lift up the console on the switches side? can you clear this up a bit, thanks.
Old Dec 23, 2009 | 02:05 PM
GR6RR's Avatar
the center console is divided in two pieces. 1 where the buttons and shifter. and 1 where the arm rest is. remove your shift ****... open up your arm rest.. and you will see its divided... slide your fingers under on the side... and just lift it with your fingers, its like snapped in place..
Old Dec 23, 2009 | 02:10 PM
KuStOm101's Avatar
That's whatsup man, appreciate your help and the quick response
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Rokafor
Jul 29, 2015 11:50 PM
vstypicals
Jul 20, 2015 10:55 PM
