Heated Seat Switch
Old Aug 22, 2010 | 04:40 PM
msommers's Avatar
Heated Seat Switch
This isn't a question of how to change the bulbs but rather if something is wrong with the switch or seats themselves.
Got a bit chilly last night and hit the switch the hotter setting. There are two lights, top of the switch and the bottom. Whether I push the top or bottom down, both times only the bottom light will illuminate. This happens on both the passenger and driver side switches.
Is this an indication of some electrically wrong with the switch or the seats only heating on the lower setting? Either way, this doesn't seem normal as why would they have two spots on the switch for lights but only one light up!
Cheers.
P.S. This is on an 06' 6MT coupe.
EDIT: Just got thinking here...Does it have to do with the ambient temperature or temperature setting you have in the cabin? Would seem really bizarre to not let you control high/low since it is a manual push button.
Old Aug 22, 2010 | 04:53 PM
WILLIE BEANS's Avatar
i dont recall ever seeing my switches light up when i use them .except for when i have the lights on at night ..(amber glow )
Old Sep 7, 2010 | 02:43 PM
G35Bandit's Avatar
...there is only one light...the white bars on the top and bottom of the switch, one is bigger than the other and that indicates the heat level, so pushing down on the bigger bar, you get full heat and pushing down on the smaller bar u get half heat, the light just indicates that the switch is on no matter what direction
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
master111
Sep 25, 2015 08:32 PM
invincible514
Sep 21, 2015 07:05 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
