dome/map loghts not working ..help
Old Apr 27, 2011 | 01:06 AM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
stock dome light was working
then I replace with new led bulbs
not working where is the fuse for the dome/map lights
also disconnected the neg side battery ..no luck
need to ck the fuses
where is it thanks guys
Old May 25, 2011 | 11:11 PM
hpun49's Avatar
Behind the battery
Old May 26, 2011 | 12:37 AM
amart014's Avatar
Fuse is under drivers side cabin. Drivers kick panel.. use the diagram behind the door
Old May 26, 2011 | 12:38 AM
amart014's Avatar
Fuse is under drivers side cabin. Drivers kick panel.. use the diagram behind the door.. also try flipping the leds around
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
