Clearence Strip Bulbs Question
Old May 25, 2006 | 07:08 PM
OhMyG...35's Avatar
I have no idea how to get to the bulb to replace it and I dont want to just rip stuff out! Can somebody please give me a little guidance! Any help would be greatly appreciated!!!
Thanks Chris
Old May 29, 2006 | 12:23 PM
g35rcr's Avatar
turn the wheel all the way in...pull the tabs that hold in the shroud in the wheel well...peel back the shroud and you have access to all the bulbs...turn and pull the housing for the clearance light and just replace the bulb...
Old May 29, 2006 | 12:30 PM
Dakkerz's Avatar
Just pay attention to the angle that you pull the bulb out, a couple people have had trouble putting the bulb back in because visibility is limited. Just remember that the bulb housing is keyed and will only go in a certain way at a certain angle.
Old May 29, 2006 | 01:34 PM
g35rcr's Avatar
little trick...shine a strong light into the housing so when you are in the wheel well you can see where light is coming through
Old May 30, 2006 | 12:08 AM
picolo18's Avatar
Thanks Chris
What kind of bulb is it?
Old May 30, 2006 | 11:22 AM
jiggalam's Avatar
168 bulb. Be VERY careful when you take the bulb out and put the new one back into the housing. It is very easy for the bulb to disconnect and fall into the housing. I actually ended up losing one stock bulb in the housing and have no idea where it is. I can;t see it from the front so I think I'm ok. I recommend taking the wheel off and taking off the whole liner just so you have more room and a perfect view of the connections. You can also replace your fogs while you're at it.
Old May 30, 2006 | 11:52 AM
axiochris's Avatar
hey guys
anyone find that diy that was posted a LONG time ago on how to change these lights? I was really good with pictures and detailed instructions. I used it to change my bulbsj liek 2 years ago.
recently, all my 168 bulbs have burned out. hahahaha both clearance and the side markers ? wtf!
Im sure there are newer, more improved bulbs these days. I used the piaa white/white 168s before. any current recommendations and suggestions on where to buy?
mike730
Jan 12, 2018 04:25 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
