G35 Clearance light question
Old Sep 26, 2003 | 11:46 AM
ncozby's Avatar
Re: G35 Clearance light question
I used the Extreme Whites and it matches darn near perfectly.
2003 G35 BS Sedan AT - St. Louis, MO
Premium, Winter, Xenon
35% Tint All Around - Clear Side Markers
Custom MB Quart / Eclipse Stereo System
PIAA Hyperwhites All Around & Inside
Old Sep 26, 2003 | 12:29 PM
al503's Avatar
I also had the extreme white wedge bulb for the clearance bulbs. I actually didn't like the color that much. They were just a little too purple for me. You could see the filament inside the bulb and that was the only part that was really white. The rest of the bulb had a dark purple hue. I'm going to try out the PIAA white LED's. I'll have them on Monday, along with the Plasma GT-X and can post pics if you want.
Old Sep 26, 2003 | 01:17 PM
cliverman's Avatar
How much trouble was it to replace the clearance bulbs?
Where did you buy them?
Has anyone tried Polarg bulbs?
Old Sep 26, 2003 | 01:23 PM
redwillow's Avatar
20 Year Member
i just put the PIAA Xtreme white bulbs in my Clearance lights, I also have them in the clear corners. The ones in the Clearance lights seem too blue to me, but the same bulbs look much less blue in the clear corners and seem to go good with the HID headlights. I think its something to do with the way the lens is on the clearance lights. I'll try to post some pictures.
...its not that hard to replace them, about 8 clips, 8 bolts and a couple screws to remove the wheel well panel. I did it without taking off the wheels, just turned them to get access. I got the PIAA bulbs locally at a truck options store.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Sep 26, 2003 | 01:34 PM
ncozby's Avatar
Replacing the clearance bulbs is a bit of a pain, but not that hard. You have to remove the wheel skirts, and turn the steering to give yourself room to access to the bulb cluster. Even with all that off, it's still a process of feeling around a little, because you cant see the clearance bulb fixture very well. It took me about 45 minutes to do both sides. 30 minutes for the first side, then 15 for the second side having learned the process.
Old Sep 26, 2003 | 01:39 PM
al503's Avatar
Hey Red,
I noticed the same thing. I think it might be due to the fact that only the brightest part of the bulb shows through the clear corners while the rest of the bulb surface doesn't.
Any problems with the cops on the white clear corners? I want to change out the amber bulbs in mine but I don't need any more attention.
Old Sep 26, 2003 | 02:20 PM
redwillow's Avatar
20 Year Member
no, i would be amazed if the cops in my area even knew my clear corners were not stock.
I am much more concerned about being pulled over for the blue look on the clearance lights from the PIAA bulbs.
Old Sep 26, 2003 | 04:22 PM
g35girl's Avatar
Unimaginative, Indecisive User
hey redwillow, do you have pics of your car at night w/ those bulbs on?
<font color=purple>.g35girl.</font color=purple>
Old Sep 26, 2003 | 08:15 PM
redwillow's Avatar
20 Year Member
this is PIAA Xtreme White bulbs in both the clear corners and the clearance lights
Old Sep 26, 2003 | 08:16 PM
redwillow's Avatar
20 Year Member
redwillow's Avatar
20 Year Member
you can really see the difference in color in this picture... same bulbs in both.
Old Sep 26, 2003 | 09:01 PM
g35girl's Avatar
hey redwillow... thanks for posting pics. wow those look really good on red.
Old Sep 26, 2003 | 09:22 PM
redwillow's Avatar
20 Year Member
np and thx....
baby, it ALL looks good on red!
