How to remove rear lites/ bulb info
Old Sep 30, 2003 | 08:25 AM
BillR's Avatar
I finally decided to remove a tail light and confirm what bulbs are in there.
Here is how to remove a taillight:
1. Remove black plastic trim by pulling up gently. It is held in by 4 or 5 clips.
2. Remove thin (fuzzy) plastic by popping up the heads of the snap locks.
Now the 3 nuts that hold the tail light in are exposed. You will need a 8mm wrench and deep well socket.
3. A wire harness is held by a white cap that is pushed on one of the studs. Pop that off and remove the nut.
4. The stud closest to the center is in a recessed area and will need a socket to remove. DON"T DROP THE NUT!!
5. With all 3 nuts removed, gently pull the tail light assembly out.
BillR
Old Sep 30, 2003 | 08:27 AM
BillR's Avatar
Re: How to remove rear lites/ bulb info
Here is the recessed nut towards the center.
BillR
Old Sep 30, 2003 | 08:34 AM
BillR's Avatar
The rear tail light exposed.
The replaceable bulbs are (from left to right)
Reverse lite - T16/W2 or Piaa 19224, Polarg M6
Turn signal light - T20/7440 or Piaa 19225, Polarg M2
Side Marker Light - T10/168 or Piaa 19168, 19169, 19172
BillR
Old Sep 30, 2003 | 08:35 AM
BillR's Avatar
All 3 bulbs from Left to right:
Side Marker light
Reverse light
Turn signal light
BillR
Old Sep 30, 2003 | 09:25 AM
cliverman's Avatar
BillR,
Where did you buy your bulbs?
Old Sep 30, 2003 | 01:53 PM
OOOOA3's Avatar
Alumni****
this belongs in FAQ.. thanks bill..
Old Sep 30, 2003 | 04:54 PM
ncozby's Avatar
www.optauto.com has all the bulbs. I've ordered there before and got my stuff pretty quick.
<font color=blue>2003 G35 BS Sedan AT - St. Louis, MO
Premium, Winter, Xenon
35% Tint All Around - Clear Side Markers
MB Quart / Eclipse Stereo System
PIAA Extreme Whites - K&N Drop-In</font color=blue>
Old Sep 30, 2003 | 08:33 PM
RugRatCoupe's Avatar
RugRatCoupe
20 Year Member
BillR,
Great job w/ the Pics & Descriptions.
Can you open up the Tail Light assembly to get to the LEDs or is it sealed?
I'm thinking about taking OUT the 12 LEDs That form the inner square wedge pattern (next to the back up lights) and placing them around the turnsignal housing so all FOUR ROUND LED taillights would be on for rear running lights. Can you say Skyline.
RugRatCoupe
Old Sep 30, 2003 | 10:46 PM
RamboRami's Avatar
G35driver.com Moderator
good job bill
rugrat, from the looks of it, it looks sealed, the LED's are probably on a board, so your best bet is to just custom make your own set of led's.
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Sep 30, 2003 | 10:49 PM
FDNameBrands's Avatar
Nice, thanks for the info BillR[img]/w3timages/icons/smile.gif[/img]
Old Oct 1, 2003 | 08:17 AM
BillR's Avatar
I got the bulbs at optauto.com
I did not look into seeing if the unit was sealed, but my best guess would be - yes.
BillR
Old Oct 1, 2003 | 01:17 PM
Shader7's Avatar
I love it when people take the time to do stuff like this.
/salute Bill
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero, Sat
Old Oct 22, 2003 | 03:03 AM
SkylineGT's Avatar
Nice and throughtly. As for the black plastic trim...any tricks to remove it?
2004 G35 Coupe 5AT
Black/Graphite Ltr
Tire Pkg
Old Feb 1, 2004 | 08:57 AM
amg35's Avatar
Florida G35 Club
BillR,
Do you know if these 3 bulbs will fit the sedan too?
Thanks,
amG35
2003 Silver Sedan
Old Mar 18, 2004 | 10:15 PM
nuttyprof's Avatar
how do you do this with the sedan? ive got my taillights off, but i cant figure out how to put in the bulb. its really starting to **** me off. someone please help.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
JWT popcharger + Z-tube
Stillen True Dual Exhaust
6-wire ground kit
