lights not working,which fusebox?
Old Aug 3, 2006 | 09:40 PM
cutiewolf's Avatar
hi, my dome light,door light,and i think my auto "off" headlight r not working,and also my clock light...everything else is working...which fusebox do i look into at?can someone help me out~thanks alot..
Old Aug 4, 2006 | 02:23 AM
IvoryGT's Avatar
the one in the engine compartment, it's right next to the battery against the firewall. You will have to remove the wiper shroud to see the box next to the battery and remove the cover by pulling it upwards.
Old Aug 4, 2006 | 03:09 AM
cutiewolf's Avatar
i checked all the fuse in there..i dont think i found any burn out fuse...lights still not working...wat should i do?
the lights went out because i change the dome light with a diff watt blubs,and i didnt change the doorlight bulbs.
Old Aug 4, 2006 | 03:27 AM
IvoryGT's Avatar
You need to make sure its the right box in the engine compartment you checked. If so. Check the interior fuse box next to your dead-pedal.
Old Oct 3, 2006 | 11:17 PM
Zooyrk4u's Avatar
Im having the exact same problem...does anyone know what this fuse is labeled as?
Old Oct 5, 2006 | 12:59 AM
cutiewolf's Avatar
i reconnect the battery now everything works....hmmm wouder why
its not fuse problem
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
