where can i order led's?
Old Feb 11, 2007 | 01:45 PM
Drtybrd61's Avatar
I was having the same problem with vleds.com, but it looks like their site is back up and working properly. you might want to give it another try.
Old Dec 4, 2007 | 09:53 AM
TURBOTOM's Avatar
a.k.a kleicoupe
BUMP
Dont want to start a new thread? Did VLED go out of business?
Old Dec 4, 2007 | 11:02 AM
Calvin's Avatar
Overglorified Altima
why do you say that? the website works fine for me.
Old Dec 4, 2007 | 11:51 AM
DOCSG35's Avatar
Originally Posted by kleicoupe
BUMP
Nope! I just ordered and received bulbs from them a few days ago.
Old Dec 4, 2007 | 12:00 PM
clinthammer's Avatar
if you have issues email jake@frickinbrite.com - he owns vleds. He can help you out!
Old Dec 5, 2007 | 01:19 PM
guys - be careful because I just picked up smt and high power bulbs and some of the leds in them were not matching. Some were hyper white while some had a subtle hint of blue.
According to vleds, they try their best to match the leds up before they are out the door.
I now have three smts with hyper white, and one with a hint of blue...
Old Dec 6, 2007 | 05:51 PM
05DGx's Avatar
I just bought these for my car a few minutes ago
For the plate number lights:
http://frickinbrite.com/catalog/prod...roducts_id=315
For the dome interior: http://frickinbrite.com/catalog/prod...roducts_id=379
I'll try to post a few pictures for you when I finally get them.
Old Dec 14, 2007 | 12:53 AM
ashish's Avatar
not sure if i should order from vleds or superbrightleds now..
I was going to order license plate lights, dome lights, map lights and the door lights.
Old Dec 14, 2007 | 01:01 AM
BlueDevilBAMF's Avatar
I've ordered from V-LEDs.com on two separate occasions... I now have their high power white LEDs in my clear corners, clearance strips, under-door lights, map lights, reverse lights and license plate lights.
Each time I've ordered the shipment has been prompt and the bulbs have matched very well. I would certainly recommend them to anyone.
Old Dec 16, 2007 | 05:59 PM
Ayankees2772's Avatar
Can you put up the codes for each one that you said? Im going to order all of these in the next few days and dont want to put in the wrong order. Thank You
Old Dec 16, 2007 | 10:10 PM
Xblackg35X's Avatar
i got mine at pep boys
Old Dec 16, 2007 | 10:27 PM
License Plate light: 194
Door courtesy lights: HID WHITE 9 LED DOME LIGHT 3022 3021 3175 6428 6430 (Listed under 31mm Festoon)
Reverse LEDs: 921
Interior dome lights: 31mm Festoon (3022)
Clearance Strip: 194
Front Corners: 194
Old Dec 16, 2007 | 11:07 PM
Reverse LEDs: 921
Front Corners: 194
You are the man! Im assuming two for each??
Old Dec 16, 2007 | 11:29 PM
No problem... All the LEDs I got were the "High Power White" which I would recommend, I'd double check on the website, but I think the 921's and 194's come as a pair per order, while the 3022's are only one bulb per order.
Old Dec 28, 2007 | 07:34 AM
  #30
paky786's Avatar
Did you get those picture?
