Tail Light Blinker mod?
Old Feb 18, 2007 | 02:59 AM
Polishthrust's Avatar
Has anyone figured out how to make the blinker circle light up on the taillights? Let me specify; I only want it to be on when i turn on the lights so that the 2 circles are running, I dont want it to light brighter when i hit the breaks. I know someone has hooked up the blinker circle to light up during braking and it wasnt as bright + there was a delay for some reason.
Would this be a simple fix with a 2 filament bulb + a wire, or would it take some major restructure?
I thought this would look tight at night with some overlays such as these where the square LEDs would be disconnected.
Old Feb 18, 2007 | 04:19 AM
speedracerg35's Avatar
the brakelight does not have a circle around it. what you are seeing is a mirrored reflector the circles around an incandesent bulb. take a closer look at you tailights and you will see what i mean...coupes anyway.
edit: the only way i could really think to do this would be to mix and match the guts from an 05 and newer sedan tails.
roboeclipse
Lights
Aug 13, 2015 10:45 PM
underworld
Aug 6, 2015 01:36 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
