fog lights won't work
Old Mar 1, 2007 | 12:43 PM
zjigg1k's Avatar
here is what happened, one of my city running lights blew out so I went to change the bulb. During the process, I accidentally unplugged the fog light wire. Well, after I changed the running light bulb and replugged the fog light wire, I turned the car on to test if everything was working properly. Come to find out that neither fog light is working now. So I assumed that it was a fuse I blew. So I checked all the fuses and none were blown. I then took off the wheels and got in the rear wheel again to check each fog light bulb to see if I blew them or if there was another wire unplugged but no luck. Everything seems to be fine except they won't turn on now. Any suggestions because I don't what else to check???? Also, its a 06 coupe 6mt.
Jusseth
Sep 13, 2020 12:25 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
