06 headlight Question..:confused:
Old Mar 6, 2007 | 01:03 AM
edindaclub's Avatar
if i upgrade my 03 headlight to 06 headlight, can i use my existing ballast?
abcquackyxyz's Avatar
yes. you can use them with the same ballast.
redlude97's Avatar
Yes
Old Mar 6, 2007 | 01:05 AM
Quick question...Doesnt the 06 headlights come with ballasts when you upgrade?
Old Mar 6, 2007 | 02:26 AM
avs007's Avatar
When I got my 06' headlights from the dealer, it came with everything except the bulbs.
Old Mar 6, 2007 | 02:45 PM
rasetsu's Avatar
You'll lose the parking/clearance light strip with the 06 headlight assembly though.
Old Mar 6, 2007 | 04:36 PM
Deezflip's Avatar
Are the 06 projectors have the same bulb for the 03-05?
Old Mar 6, 2007 | 04:39 PM
Mike_Deezy's Avatar
No, 06 uses differnt bulbs:
Fogs - H1
City Lights - 168 or 194 wedge bulbs
Headlights - D2S
Turn Signals - 7440
Calvin's Avatar
Overglorified Altima
nope. headlights are d2s instead of d2r, fogs are h1 instead of h4, turn signals are (uuh, i forgot. but theyre not dual filament anymore. it's either 7440 or 7443 or something, lol.).
Old Mar 6, 2007 | 07:00 PM
SPCG35's Avatar
06 headlights
I just got some
Old Jun 13, 2007 | 08:16 PM
RedG's Avatar
<--12 More Years
Help
Is there any way not to loose it, by re-wiring it. I'm doing this NOW, anybody know what wire to tap into?
Thanks
Old Jun 13, 2007 | 08:23 PM
sfgr415's Avatar
^^^ The clearance strip doesn't exist on the 06+. They are just not there. Nothing to re-wire although I have seen some people cut the housing and install them.
redlude97's Avatar
Thanks
there is no clearance strip there to rewire it to. You'd have to dremel out the clearance strip spot, and retrofit the 03-05 clearance strips in. IvoryGT has done it and can helpt you out with it if you are really interested.
Old Jun 13, 2007 | 08:25 PM
lowrider's Avatar
Thanks
There nothing to rewire to. There is no clearance strip with the '06 projectors, just an ornamental one. Some guys have spent $ putting clearance strips on the lights however. IvoryGT, the headlight wizard, has.
Lou
Old Jun 13, 2007 | 08:30 PM
RedG's Avatar
<--12 More Years
ok my bad forget the strip...how about the regular parking lights, on my 04 there are two amber lights next to the fog lights, which are also the turn signals,is this light not the same for the 06, cuz mine don't turn on?
