HID Headlight Buld Replacement?
Old Mar 7, 2007 | 03:09 AM
808MIKE's Avatar
Hey guy's, is there a Replacements Bulb that had a more Blue/White Tinge? Instead of the Yellow/Blue Tinge we have now? I spoke to a guy that Changed his, but forgot what Bulb Number it was? Think The brand was "Philips" Bulbs? Which had a more Blue\White color to the Bulb when on? Anyone got any more Info for this? Or a Number of the Bulb that has this Color or Brand?
Old Mar 7, 2007 | 07:25 AM
SPEEED's Avatar
Bad Toro
Of course you also have to remember that the higher the Kalvin, the lower the light output is. There is certainly a sacrifice here.
Does anyone know the stock K ratings on Bimmers?
Old Mar 7, 2007 | 08:39 AM
GR8TG35's Avatar
^ +1
What Speeed said.......the higher the temp bulb, the lower the output of light.
It may look brighter, but in reality it diminishes your distance of vision.
Philips 6000 temp are probably the most common up/down grade bulb used.
Old Mar 7, 2007 | 11:18 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Stock bulbs are 4100K. Some of the later G35s came with 5000K stock. But no stock car is 6000, 8000, 12000, or 30000K.
http://www.svtperformance.com/forums...d.php?t=362736
Here's a funny thread where someone's trying to spread misinformation about stock bulbs:
"Well if you hate it so much, you should start trying to take down BMW, because most of the new models have the 8000k headlights which are a crystal blue."
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
as25656800
Aug 9, 2015 07:25 AM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
