inside cabin lights
Old Apr 17, 2007 | 04:51 PM
Jedunnigan's Avatar
Originally Posted by Floyds_racing
For a set of four its $80...not bad at all. Thanks a lot.
Old Apr 17, 2007 | 05:23 PM
HLMAX's Avatar
Here are 10 piece lots of 9 white LED festoons for about $60.
The lot will do the whole interior and then some.
http://frickinbrite.com/catalog/prod...roducts_id=236
Old Apr 17, 2007 | 06:28 PM
Floyds_racing's Avatar
there is only 4 in the int right? the two in front and 2 map lights in back!
Old Apr 17, 2007 | 06:30 PM
Originally Posted by soad
70 thats alot
Old Apr 17, 2007 | 06:52 PM
HLMAX's Avatar
6 festoons in the interior. 4 map lights and 2 under the front doors.
There are lots of room in the front map lights. You can go fancy and connect two festoons in parallel for a total of 18 LED for each of the front map lights.
Old Apr 17, 2007 | 07:05 PM
what are the ones in the rear?
Old Apr 17, 2007 | 07:36 PM
HLMAX's Avatar
Here is a site for bulb references.
Go here and punch in your year and model.
http://www.sylvania.com/ConsumerProd...de/default.htm
Old Apr 26, 2007 | 08:32 PM
G35Ivy's Avatar
check this out.
they are front www.iJDMTOY.com, his ebay store is http://stores.ebay.com/MotoringMax
Old Apr 27, 2007 | 10:21 AM
clinthammer's Avatar
how can you see in that light inside???
Old May 2, 2007 | 07:12 PM
Red_G35's Avatar
Originally Posted by G35Ivy
check this out.
What size bulbs did you use for the clearance lights and side markers? Are they LEDs, any strobing?
Old May 2, 2007 | 10:52 PM
side markers are 164/198 (ive bought the 12led from superbright) and clearance/step light are festoon 31mm 3022.
Old Jun 23, 2007 | 07:41 PM
bobshuai's Avatar
Originally Posted by clinthammer
is this the festoon 9led
I don't think that can fit in our map light right??
Old Jun 23, 2007 | 07:49 PM
bobshuai's Avatar
They don't have it for out car. I can't even select Infiniti.
Old Jun 24, 2007 | 01:46 AM
sfgr415's Avatar
These will work for sure. I have them in my dome lights and under the doors. They are bright as well:
http://frickinbrite.com/catalog/prod...roducts_id=135
Old Jun 25, 2007 | 05:37 PM
  #30
bobshuai's Avatar
Really so this will fit G35 coupe's map light? Because coupe only have dome lights at the front and we don't have dome lights at the back.
