HID Flicker...question
Old May 16, 2007 | 01:15 AM
gwhizz35's Avatar
I noticed on the 06 Coupes and up with the HID projector lights, ,that it does not have the same 'purple/blue flicker' from different angles like BMWs, and Audis do. What causes that?...and how come the G's lights don't have that?
Old May 16, 2007 | 02:20 AM
redlude97's Avatar
it is because the 06 projectors use a fresnel lense which has ridges on it which blurs the cutoff and results in no color at the cutoff to cause the flicker effect you see in other cars. Alot of newer projectors are going towards this route. The only way to get the flicker effect is to open up the headlights, and swap the fresnel lense for a clear lense such as from a tsx projector, and mod the shield for some color.
Old May 16, 2007 | 02:32 AM
ttrank's Avatar
Grocery getter
You can always do a color mod to get that wide color beam.
Old May 16, 2007 | 02:39 AM
gwhizz35's Avatar
got it...thanks guys...man red...you really broke it down in details!...thanks!
wonder why the Infiniti line of projectors for all the models don't flicker...but most Euro cars' projectors do...weird...I like that flicker affect...seems too much trouble.
Old May 16, 2007 | 03:06 AM
redlude97's Avatar
alot of newer cars no longer flicker, and fresnel lenses are becoming more popular because a super sharp cutoff can cause eye fatigue. Having no color doesn't decrease output any, so its really an aesthitic thing. That being said, I'm in the process of doing the colormod, and IvoryGT does it for a fee, PM him if you are interested.
Old May 16, 2007 | 03:12 AM
ttrank's Avatar
Grocery getter
IvoryGT is the go-to man for this stuff. He just did a sick set of 06 projectors. He helped give me advise on the S2k and TL quad projectors I have on my sedan. Great guy!
Old May 16, 2007 | 05:20 PM
IvoryGT's Avatar
DOT(US) is more strict than ECE(Europe) It's not before long they will make European cars confirm DOT specs.
Basically the flicker comes from the split second of time that the color from the cutoff of the projector is seen. If you have slight color on the wall or on the ground at the distance it will flicker. If you have no color at all, it will just appear white. If you have too much color from a thick color band, you will have a consistent color at a distance (blue or purple) and it will not flicker because of how much color there is.
So it's up to your own preference. Read up on the color mod on my sig and you too can make your car lights flicker.
Kelvin Style006
May 23, 2016 03:47 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
MrIP35
Oct 25, 2015 11:13 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
twentyeggs
Sep 11, 2015 03:58 PM
