Help????? How To Adjust 04 Headlights?
Old Jun 5, 2007 | 01:55 AM
g35man04's Avatar
CLUB MODERATOR
the headlight recall campaign overall was poorly executed. The dealerships installing them didn't have the proper training/techs to do the installs properly, which resulted in a bunch of shoddy installs. Mine weren't aligned straight at all, and I had to spend an extra 3 hours getting them perfect again. Any time the headlight is removed from the car, there is going to need to be some adjustment and nudging to get the headlights centered and with the correct leveling, something I doubt the dealerships were willing to do. I'll bet they didn't even do a beam alignment and just swapped them out for the new ones, but thats a whole other matter
Well to answer your solutions my headlights have been removed from my g35 about 4 or 5 times now. When i had the Halos and CCFL clearance strips removed the whole headlight was taken apart.....so after reading how you just wrote that removing them can cause them to bot be aligned.....I have never realigned my headlights since removing them.....I just put them back in the way they came out. Could adjusting them help this problem? Im about to remove them again to get one my halos fixed and i have to send it off. so my other 04 set i have will be going back on in the meantime. I may order a set of 06 though and send them off for a retrofit. I will see though..I have sent ivorygt a message and was checkign to see on how much it cost to get the retrofit done.
Old Jun 5, 2007 | 03:26 AM
redlude97's Avatar
I'm not saying they aren't aimed incorrectly, I'm saying make sure that iss the issue before just blindly raising your headlight aim.
Old Jun 5, 2007 | 03:31 AM
OkinawianKid's Avatar
can someone tell me what year the recall is for, i have an `04 and im out of the country for like a year, so i would like to know if i need to send my car to the dealership... Thanks!
Old Jun 5, 2007 | 03:34 AM
Calvin's Avatar
Overglorified Altima
it's only for certain projectors. you have nothing to worry about with your reflector housings.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Fox843
Nov 7, 2015 05:43 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
