Who makes the best one out there.
I bought a 5000K McCullough kit and the the low beam (fog) has great output, but the High beam absolutely sucks!!!!
the problem is that it has a solenoid that moves some shield out of the way for the high beam.....sounds good in theory, but the problem is that the burner is in the wrong position to give good light to the high beam reflector. I think I need an H4 bi-xenon bulb (kit) that moves the buld in and out depending on whether you need the fog or the high beam on......
anyone have any good recommendations???
there are none, all plug and play kits suck. Go back to stock or do a projector retrofit. You are being inconsiderate of other drivers on the road by installing those in your lower bowls.
I was think thinking of a TL bi-xenon projector to go with my TSX low beam projectors, but I am not impressed with the Bi-xenon high beam on that prjector.
Just do a TL projector retro. I know it is not cheap but does make it a lot better.
As for your question, go for one of the quad filament/quad ballast kit. The only problem is that your high beam flash won't do much.
