g35 lights for 2003 vs 2006
Old Jun 18, 2007 | 02:57 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by G-Mony
Do these fit the sedan? or does the 06 sedan have these lights too?
they do not fit the sedan, they are completely different shaped lights between the coupe and sedan.
-GP-
Old Jul 17, 2007 | 09:18 PM
shdowflare's Avatar
Help!
I'm finally installing my '06 headlamps and am having a problem.
I just pulled out the old '03 headlamps (which were only connected by one harness). I noticed there are three harness plugs on the '06 headlamp assemblies. But only one on my old '03 headlamps. So I plugged in the one '06 harness (the biggest one, which is the only one of the three that will fit) and only the small city light works. Nothing else.
What am I missing? Do I need to hook up those other two harnesses to something? Maybe some hidden harness somewhere?
Thanks
B
Old Jul 18, 2007 | 12:25 AM
Need4SPEED05's Avatar
What??? 3 plugs? No there should be only ONE male plug on the headlight left for you to plug directly onto your car. All the other plugs are ones that you plug into bulb on the headlights or straight into the ballast. Take a good look at the back of the headlight and make sure you have all plugs plugged in except for the big one (which is just a big socket not a plug) that goes directly onto the plug from your car. I did mines the other day on my 05 but it took some wiggling on one side to fit because I was in a front end collision on that side. Also installed an 6000k HID conversion on the fogs and they look nice. They make the projectors look a bit yellow though. Good luck.
Old Jul 18, 2007 | 01:05 AM
shdowflare's Avatar
Yeah I figured it out. Once I moved the ballasts over to the new headlamps, those other two "plugs" went right into the ballasts. Works great now. I put in the Luminics JDM Yellow H1 fogs too. I'll be putting in the Philips 85122cm 4800k D2S bulbs in the next week or so for a more pure white HID look...here are some pics.
Thanks,
B
Old Jul 18, 2007 | 05:17 PM
Nice. I hope you enjoy them. Good luck with the 85122cm's. I may get the phillips ultinon's to match my fogs. How did you get your hands on a pair of those bulbs anyway?
Old Jul 18, 2007 | 06:39 PM
shdowflare's Avatar
Which bulbs? The 85122cm? Got a GB going with XenonFactory...they're one of the few vendors who actually carry them.
Take care,
B
Old Aug 7, 2007 | 12:25 AM
KapVu's Avatar
I'm thinking about buying the 06 headlight housing with projectors for my 03 coupe. Will I need 06 ballast, bulbs, etc? Or is everything usable from my stock 03 coupe?
All I will need to get is the 06 headlight housing withe projectors right? Thanks.
Old Aug 7, 2007 | 02:00 AM
redlude97's Avatar
and bulbs
Old Aug 7, 2007 | 03:37 AM
Triji's Avatar
also FYI.....
________________________________________
2004
2004 INFINITI G35 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
High beam headlamp
9003
9003ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9003XV XtraVision Halogen Upgrade: Up to 30% Brighter
9003CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
168
Front turn signal
7440
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9003
License plate
168
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
194
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
LINK TO LIGHT GUIDE
http://www.sylvania.com/ConsumerProd...lacementGuide/
2006
2006 INFINITI G35 (Coupe)
Low beam headlamp
HID-D2R
High beam headlamp
9003
Parking light
168
Front turn signal
7440
Rear turn signal
7440
Tail light
LED
Stop light
LED
LED
Fog/Driving light
H1-55W
H1ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H1XV XtraVision Halogen Upgrade: Up to 20% Brighter
License plate
168
Back up light
921
Front sidemarker
194
Rear sidemarker
194
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
Old Aug 16, 2007 | 03:16 PM
G35Sask's Avatar
Originally Posted by Triji
also FYI.....
2004
Low beam headlamp
HID-D2R
High beam headlamp
9003
Parking light
168
Front turn signal
7440
Rear turn signal
7440
Tail light
LED
Stop light
LED
LED
Fog/Driving light
9003
License plate
168
Back up light
921
Front sidemarker
194
Rear sidemarker
194
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
LINK TO LIGHT GUIDE
2006
Low beam headlamp
HID-D2R
High beam headlamp
9003
Parking light
168
Front turn signal
7440
Rear turn signal
7440
Tail light
LED
Stop light
LED
LED
Fog/Driving light
H1-55W
License plate
168
Back up light
921
Front sidemarker
194
Rear sidemarker
194
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
I'm not sure if I read this right, but there is no difference between bulbs used from 2004 to 2006 setup, whats the difference between the headlight units itself? Is 2004-2006 the same and pre-04 different? I am trying to understand why everyone is upgrading to 2006 light set ups. Sorry.
Old Aug 16, 2007 | 03:55 PM
IvoryGT's Avatar
the info is wrong.
04 has D2R HID bulbs for low beam, dual filament H4s for foglight and high beam
06 has Bi-Xenon projector using D2S bulbs which includes low and high beam, foglight is just H1 bulb single filament.
the turnsignal on 04 is dual filament 7443
the turnsignal on 04 is single filament 7440
Old Aug 16, 2007 | 05:52 PM
G35Sask's Avatar
Another question since you seem to be on the ball with the subject.
I was considering going to the 06-07 projector set up myself... And reading it seems the Canadian car (mine) is different from the US with the daytime running lights wiring.
IF I could find a wrecked 06 or 07 in Canada and buy the projectors for my 2004 model coupe, would the units just swap in and out no extra messing around seeing as they are both Canadian?
Thanks
Old Aug 16, 2007 | 05:55 PM
Gam3's Avatar
direct swap...mine should be coming in real soon..ordered them already
Old Aug 16, 2007 | 06:08 PM
G35Sask's Avatar
Where did ya find them if you don't mind me asking, and how reasonable a price?
Old Aug 16, 2007 | 08:10 PM
  #30
IvoryGT's Avatar
Thanks
In short yes.
Because the DRL the wiring needs to be messed with if you get a US unit to put in your CA car. So if you can find newer model G in CA it'd work out. Unless of course they do away with the DRL or wired it even more weird.
