TSX retro fit....
Old Jun 25, 2007 | 07:22 PM
TurboDreamzG's Avatar
TSX retro fit....
What's up guys, i'm breaking down and doing a projector retro fit for my new 06 headlights that i just got. i'm going to go with the QUAD projector setup. I know the TSX lense will fit the (FOGLIGHT)Lower light but will they fit the low beam as well. I'm putting all 4 projectors from TSX in the lights and just need to confirm that they will all fit and or are the same size.
Old Jun 25, 2007 | 07:27 PM
redlude97's Avatar
You need to so some more research, the tsx lense will not fit the foglight because there is no projector there for you to swap the lenses with. Installing 4 tsx projectors would IMO be a bad idea, as you will lose your bixenon capability of the stock projector. You are better off colormodding the stock projector with the tsx lenses, and installing a set of projectors in the foglight area by replacing the foglight bowl with another projecter such as the tsx's or a similar projector.
Old Jun 25, 2007 | 07:33 PM
ttrank's Avatar
Grocery getter
Talk to IvoryGT, he has done a lot of work on the 06 lights.
Old Jun 25, 2007 | 07:39 PM
sfgr415's Avatar
The TSX lenses will fit in place of the bi-xenon low beams. As for the fog light area, you will have to do some custom fabrication.
TeamNoSleep
Sep 13, 2015 07:40 PM
kennyq45
Nov 25, 2010 05:40 PM
prelude555
Oct 28, 2005 03:35 PM
plux79
Southern California
Oct 12, 2005 12:35 AM
JaTe
Oct 5, 2004 02:58 AM
