Headlight Recall 06 Coupe
Old Aug 8, 2007 | 09:51 PM
scozec's Avatar
I am debating on whether to take my car in to fixed the 06 recall on the headlights?
Do they actually replace the whole unit ( including the clear shell case)???
Help!
Old Aug 8, 2007 | 09:52 PM
Beebo's Avatar
yes they replace everything!!!
i say dont do it!
Old Aug 8, 2007 | 09:56 PM
TRIG's Avatar
don't do it. They ended up ****ing the alignment on my lights. After 3 visits the light is still F***ed up. Don't do it.
Old Aug 8, 2007 | 10:01 PM
scozec's Avatar
Is it worse off after they replaced it?
Old Aug 8, 2007 | 10:08 PM
Beebo's Avatar
most say they are
Old Aug 9, 2007 | 01:07 AM
Rphillips6487's Avatar
yah im not getting mine lol
Old Aug 9, 2007 | 06:10 AM
jzhu625's Avatar
what do they actually replace when you take it in for recall? i just got mine 06 few days ago, i'm not sure if they've done the replacement for my headlights.
quick question, what's the different after when is replace? a completely different headlight or just adjustment? and can any post the differents between those two headlights? thanks
Old Aug 9, 2007 | 03:44 PM
ElixXxeR's Avatar
My mother had the recall done on her 2004 FX and they replace the entire headlight assembly. The FX lights are now brighter and have a better spread, but it seems that owners say the G35 lights take a step backwards, so I've declined.
Old Aug 9, 2007 | 03:58 PM
izmir41500's Avatar
G35driver Addict
it's just the driver side aimed too high. there's a DIY adjustment on here.
Old Aug 9, 2007 | 11:51 PM
tiguy99's Avatar
Yeah its really quick and easy. Just aim the driver side down with a #8 size wrench and you're all set. I used a socket wrench to adjust the set of lights I have now
Old Aug 10, 2007 | 12:36 AM
plaguevc's Avatar
for real? so it's not an actual defect on the headlight itself, it's just misaligned? So it's not brighter, not a better spread... nothing?
Old Aug 10, 2007 | 02:50 AM
old_s13's Avatar
Where are you guys getting all this mis-information? Too much speculation.
The recall is not mandatory, its voluntary through INFINITI and it involves low-beam photometry, hence the reason for the revised (new) headlamp assemblies. If you have the opportunity, do it. Its not a major issue, but its an improvement, nonetheless.
Once the updated headlamps are installed, having them aligned is NOT a hard task. If you or your dealership isnt able to properly align your lamps, you should consider finding a more reputable place for service.
Cheers,
Mike
itgogitrev
Lights
May 2, 2016 06:53 AM
bTanz
Oct 15, 2015 02:31 PM
newg37
Jul 26, 2015 09:32 AM
attarday
Jul 15, 2015 04:03 PM
